saeedplc
- Nov 27, 2021
- 126
Dear Experts,
I have a question regarding G4 filter (used in air handling unit)differential pressure switch adjustment please assist me;
As far as I know, each G4 filter has a initial pressure and final pressure that means if final pressure is reached
that filter should be replaced but the mentioned pressure is according to the nominal flow passing from the filter.
Now my question is that how should I adjust differential pressure switch if flow passing the filter is 10% of it's nominal flow
to know that filter is dirty?
Another question : Do you replace your AHU filters based on time or differential pressure switch alarm?
