Fin fan cooler leak from strength weld (tube to tube sheet)
Kannn
8
Hello engineers , i have a leak from a fin fan cooler , its type is plug type fin fan air cooler , the leak is from the strength weld between the tube and the tube sheet ( the strength weld had failed ) , i want to elimnate the leak , i know that plug will not be that sufficient, is there any way that i can repair this , like an expander to enter inside the water box and expand the tube , attached images for illustration
Waiting your support and help
Ream the tube ends and remove it.
Then weld plugs into the holes in tubesheet.
