Hello Guys,
We have a problem with the machine. The pump mentioned in the scheme position 112 doesn't give pressure to the other manifolds. We tried to close the pump delivery and the pressure was around 180 bar, which means the pump is ok and probably there is some leakage in one of the manifolds. What is the quickest way to find out the leak without having to check and every component? Is there a way. Sorry I am a software guy with a passion to learn hydraulics. Also, what is the use of the second compensator in the diagram. Generally only is pressure and the other is load sense, but here but looks the same. Can some on explain me. please
