Find the Length of a text string in units.
Thawlro
Computer
Feb 26, 2004
8
Is there a way to find the length of a Text string in untis not characters?. I am building a VBA program for AutoCAD.
The length of an existing text string in the drawing, or the length of a new text string that you know the characters of?
Thanks for repling. It is the length of a text string The use will be putting in the drawing and it is unknown. Now having said that...I need to put have the text underlined. If I cannot get the length of he string, is there away to underline the text being entered. the code i am using is:
Set TextObj = ThisDrawing.ModelSpace.AddText(UCase(ViewText), PickPoint, TxtHeight)
TextObj.color = 50
TextObj.Alignment = acAlignmentBottomCenter
TextObj.TextAlignmentPoint = PickPoint
The method GetBoundingBox should get you the height and width that about any AutoCAD object would occupy.
"Whether you think that you can, or that you can't, you are usually right "
.. Henry Ford
