Bilge_Rat
Marine/Ocean
- Oct 23, 2023
- 1
Good afternoon,
I'm attempting to find a set of different volumetric flow rates for a fan based on different hertz of the VFD to use as inputs for a dispersion modeling program. Based on a technical document for the garage, I know the fan's minimum flow will be 745 CFM and the operating maximum flow will be 11100 CFM. I need to find the CFMs at [minimum + 20% speed range, minimum + 40% speed range, etc.] but I'm tripping up on determining how to go about doing so.
The facility has provided the fan curve (which I've attached) and I used the pump/fan affinity laws in conjunction with the requested operating conditions to find the maximum and minimum rpms. Appling the needed operating percentages (min +20%, min +40%, etc.) in conjunction with the min and max rpm, I found the rpm at each level and used the affinity laws again to get the volumetric flowrate. I realized this achieved the same as just doing [min + ((max - min) * % speed range)] and got me questioning if this was the right approach.
Doing the same above with bhp (with the appropriate affinity law) seems to give me a different set of volumetric flow rates. Should I be using hp and affinity laws to determine flowrate, or does just multiplying the min and max capacities as stated in the paragraph prior suffice?
Appreciate the help.
