Finding S11, S22, S12
SarahMatta
10
Hello everybody,
I am trying to have the results of S11, S22 and S12 for a model but the problem is that in the list of variables, I can only choose S11 and S12 but S22 doesn't appear.
I've tried to see in the field output but i cannot find S22 so i can select it.
Please if anyone knows what i should do i will be thankfull,
Thank you
Sarah
Was it requested as Field Output?
What element type are you using?
The problem is that S22 wasn't in the field output, I just found S11 and S12
I am using beam elements (B31)
You'll find the answer in the manual.
Users Manual 29.3.8 Beam element library -> Section: Element output
Thank you so much i'm going to check this
