tmengineer
Chemical
I'm using Finglow 3D December 2013 to calculate the minimum shell thickness of a tank which is required to withstand a vacuum pressure of 100 mbar made from SS 304.
I'd like to know the figure that Finglow uses for the yield stress for BS 1501-304-S11 but cannot find it on the program.
The tank is 5mm thick but in the calculations the minimum required thickness is 5.12 mm - if Finglow is using a yield stress less than the yield stress of the material we use to build the tank then it may meet the ASME VIII requirements without having to move to a 6mm shell.
Any feedback would be greatly appreciated!
Best,
Tom
Best,
Tom
