FIRE DAMPER LOCATIONS 2
3
0
0
NG
What are the criterias that that to be considered to identify locations for installing fire dampers in HVAC system.
Where your ducts and openings pass through a fire separation as determined by the architect a fire damper is required.
In some instances you can run your duct within a fire-rated enclosure passing through a rated room and avoid the fire damper. The enclosure effectively creates a space outside of the rated room.
IMC has 2 definitions ..... fire barriers and fire partitions ........ also sprinklered and non-sprinklered
I spec UL-555 dynamic rated dampers with the curtain out of the airstream
