Luuk21
Chemical
- Oct 21, 2023
- 24
I have the following problem;
We have certain big lines (DN100 till DN250) that are not fire protected (they are insulated but not fire proof). When a fire occurs and the fluid is heated up to 100 degrees Celcius, a chemical reaction could (theoretically) take place. During the fire it is assumed that the electrical installation fails so the line is stagnant.
We want to make sure that the temperature does not reach 100 degrees Celcius within 60 minutes - fire shielding is not possible so we want to apply fire proof insulation. My goal is to calculate the required thickness of the insulation, but I'm unable to find an generally accepted equation for this particular problem.
There are multiple formulas available, I'd like to know if there is a recommended practise/standard.
All relevant properties are known;
Cp, k, rho, epsilon, sigma, etc.
Kind regards,
Luuk
Kind regards,
Luuk
