thkurian
- May 18, 2015
- 16
When engine driven vertical turbine type fire water pup is shop tested, right angle gear box temperature is found to be 62 deg above ambient for radial bearing and 42 deg above ambient for thrust bearing. Pump is 5000 gpm capacity with head of 132 m. Same temperature is found in similar 4 pumps. Gear box sizing is checked and found meeting power rating, downthrust and speed. What can be the causes? which one is likely to be faulty - gear box or pump?
