Firebox quality steel
Biss73
13
I'm working on an 1948 heat exchanger which has a shell in SA-201 Gr B FBQ.
Does an FBQ grade steel respects by default ASTM A300?
If yes, is the -50F minimum temperature requirement (seen in some threads) valid for all steel under A300?
If no, does anyone know what is the minimum temperature requirement when a steel is FBQ?
Thanks,
Biss
No. I reviewed my copy of ASME SA 300-52 and flange or firebox quality steel could be specified to meet SA 300. It depends on how the steel was supplied - fine grained. Coarse grain could also have been supplied.
No.
FBX "Fire Box" quality simply means fully Silicon deoxidized "killed" steel.
So having a firebox quality steel does not necessarely translate into a lower mdmt?
Thanks,
Biss
SA-201 Gr B FBQ was replaced by SA-515 Gr 60 in 1967. Does someone know if they have the same Fig UCS-66 B curve?
Thanks again,
Biss
