Inchtain
Petroleum
- Feb 21, 2021
- 149
After inspecting of a fired cylindrical vertical heater, two radiant tubes were dented (mechanical damage)at about the medium length of the tubes (photo attache).
From where does this defect result from? How one can confirm such defect is acceptable to remain for several years until the next shutdown? or when tube replacement is necessary?
Fluid: Water
DT; 180 degrees Celsius
DP: 700Kpa
CA: 1.5 mm
Tube: 6"
Tube material: A106 Gr. B
Have a nice work and day
Fluid: Water
DP: 700Kpa
CA: 1.5 mm
Tube: 6"
