Fireproofing tube steel. 1
EKizak
7
0
0
I have a condition were an exterior girder abuts a stairwell. As a result I have an lu of 15ft. I would like to use a HSS section to minimize the width and keep the section in the plane of the wall studs. However, the Architect does not know of any approved UL ratings for this assembly. This does not make sense to me because the fireproofing requirements are based upon the ration of weight to heated perimeter, and a tubes ratio will significantly greater then a WF hence better fire resistance. Has anyone had this issue? How was it addressed?
CIDECT ( has information on fire resistance of concrete filled columns... earliest work I'm aware of in this area were columns for a stairwell that were done about 30 years ago at the U of Winnipeg.
Other than that, I'm aware of intumescent coatings that I've used for mezzanine areas.
Dik
Great answers, however the problem is not with the column. It is with the girder. Apperently UL does not list an assembly for a tube section used as a beam. UL has several listings for tube sections but only when used as column or brace members, ie P>>M.
Thanks, WillisV: Article should include that a the cross-section for a flexural element is less highly stressed than for a column and that as temperature rises, not only does the yield strength diminish, but also the Young's modulus.
Dik
