Fix a Part using CATIAConstraints in VBA
Jegsaran
Automotive
IN
Hello Everyone,
I'm trying to fix a Part in an assembly using constraints but I'm getting (method "AddMonoEltCst") Error.
Below is my code,
Set oDOC = CATIA.Documents
Set oTemplateDoc = oDOC.Add("Product")
Set oTemplateDocProd = oTemplateDoc.Product
Set oTemplateDocProds = oTemplateDocProd.Products
Set oTopAssy = oTemplateDocProds.AddNewComponent("Product", "")
oTopAssy.Name = "Assy - Section.1"
Set oTopAssys = oTopAssy.Products
Set oTempltAssy = oTopAssys.AddNewComponent("Part", "")
Set opartDoc = oTempltAssy.ReferenceProduct.Parent
Set oTempltPrt = opartDoc.Part
Set constraints1 = oTopAssy.Connections("CATIAConstraints")
sItemName = oTempltAssy.Name
Set reference1 = oTopAssy.CreateReferenceFromName(sItemName & "/!" & "/")
Set constraint1 = constraints1.AddMonoEltCst(catCstTypeReference, reference1)
 https://files.engineering.com/getfile.aspx?folder=c86b3c6c-43b8-4b7e-8690-decd66521f3b&file=Constrain.PNG
Most likely an input string in CreateReferenceFromName is invalid.
Here's what you can do:
1. Create document structure and fix part manually
2. Select created constraint in the tree and access it in VBA with CATIA.ActiveDocument.Selection.Item(1).Value in debug mode.
3. Use APIs to retrieve Reference to constrained part and check it's DisplayName property. What you're going to see is the correct reference string.
Thanks found the issue. Here is my code,
Set oDoc = CATIA.Documents
Set NewDoc = oDoc.Add("Product")
Set NewDocProd = NewDoc.Product
Set CollNewDocProd = NewDocProd.Products
Set NewProd = CollNewDocProd.AddNewComponent("Product", "")
Set NewProdDoc2 = oDoc.ITEM("Product1.CATProduct")
Set oTopAssy = NewProdDoc2.Product
Set CollNewProd = NewProd.Products
Set NewPart = CollNewProd.AddNewComponent("Part", "")
Set oPartDoc = oDoc.ITEM("Part1.CATPart")
Set oTemplatePart = oPartDoc.GetItem("Part1")
Set ColloTopAssy = oTopAssy.Products
Set oTemplatePartAssy = ColloTopAssy.ITEM("Part1.1")
NewDocProd.Update
Set reference1 = oTopAssy.CreateReferenceFromName(oTopAssy.Name & "/" & oTemplatePartAssy.Name & "/!" & oTopAssy.Name & "/" & oTemplatePartAssy.Name & "/")
