When you have a fixed volume steel vessel totally filled with water (no air), and the tank temperature is raised by say 30deg C from ambient. As the water tries to expand due to volumetric expansion but can't as it’s a fixed volume, it will raise the pressure within the tank.
How is this pressure calculated as a function of temperature rise??
