Hi all,
Typically, if we had a reinforced concrete beam spanning between two RC columns, cast monolithic, we could treat the beam as fixed-fixed and provide mid-span bottom reinforcement and top reinforcement near the supports.
However, if we decide to design the beam conservatively as simply supported, will the concrete behave as simply support as it is detailed in this way? Initially if it behaves as fully fixed until the top of the concrete cracks in flexure at the supports, would it then shed load to behave as simply support as that is how the reinforcement is detailed (bottom only)? If we are designing a beam as simply supported, how much reinforcement should be specified at the supports to prevent flexural cracking?
Thanks!
Thanks!
