Bobby46
- May 29, 2018
- 47
I'm working on developing a strut and tie model for the new AASHTO requirements. I have a grade beam between two drilled shafts. The drilled shafts have a fixed connection to the tie beam. It seems like there is a good bit of flexibility in how you choose to model a problem in the strut and tie method. How would you model this fixed connection? The possibilities that I see right now are:
1. The strut and tie model would have a single reaction at each drilled shaft. Model the strut and tie truss with simple supports. Detail rebar to create a fixed connection into the grade beam.
2. The strut and tie model would have a single reaction at each drilled shaft. Model the strut and tie truss with fixed supports to simulate additional forces in struts/ties. Detail rebar to create a fixed head connection into the grade beam.
3. The strut and tie model would have 2 reactions at each drilled shaft. Reactions would be located at centroid of tension and compression stress in drilled shaft cross section. Model the strut and tie truss with simple supports. Detail rebar to create a fixed head connection into the grade beam.
I intend to design the grade beam using strut and tie. I do not think the strut and tie method is particularly well suited for design of the drilled shaft due to quantity/uncertainty of reaction locations. Is there any merit to using a more complex analysis like Option 3 if I don't plan to use strut and tie forces in the drilled shaft?
Does anyone see a better/different approach?
Attached is a sketch showing my general configuration for Option 1/2.
