fixex axes in matlab gui
alexrait1
Computer
Aug 24, 2004
1
hello,
When I plot some kind of animation on a figure, the axes are resized whenever the dimension of the object changes.
can I have it fixed to some size? I use matlab gui, but I don't find the correct property.
Code:
axis manual
freezes the axis to the current settings
The appropriate axis properties are 'XLimMode', 'YLimMode' and 'ZLimMode' which should all be set to 'manual'.
After you have done that, you can set the axis limits using the 'XLim', 'YLim' and 'ZLim' axis properties which are in the 2 element vector form [min, max]
M
Dr Michael F Platten
