ShuklaPK
Automotive
- Jul 4, 2016
- 11
I am working on a product which requires fixing of a 2.5mm thick sheet (FRP Material) on the exterior panel of a Vehicle (0.65 mm thickness).
Constraint:
1. The fixed product will undergo various weather conditions (Hot-Cold-Hot (2 Deg. - 50 Deg. Celsius) + Rain + Wind(15-70 Kmph) & designed life should be minimum 2 years.
2. Lesser Cost.
Problem:
What fixing method should be used to attach the FRP sheet to the exterior panel?
My Solution:
Weld a Flat Head Bolt (Picture attached) on the Surface of the exterior panel after cleaning the panel surface, later drill holes on the FRP sheet as per Bolt size and fix the FRP sheet on the panel using appropriate size nylon Lock Nut.
If anyone can suggest a better method or can point out a flaw in my current method?
Thanks in Advance,
Pratik Shukla
Constraint:
2. Lesser Cost.
Problem:
My Solution:
Thanks in Advance,
Pratik Shukla
