MartinLe
- Oct 12, 2012
- 394
For a while now, I'm wondering about the relative pros and cons of pipe couplings (like this: vs. flanged connections in piping.
[ul]
[li]From actual quotes from contractors, I see no huge difference in price between a flange connection (consisting of collars and loose flange or two fixed flanges and bolts/work) and a coupling.[/li]
[li][/li]
[li]Couplings allow some play in distance between the pipes (up 45mm in large pipes if I read the sheet correctly and use the extra band)[/li]
[li][/li]
[li]Installation time should be far quicker if I consider the time for welding[/li]
[/ul]
... so it looks like, for pipe-pipe connections, these couplings have a few clear advantages (That may not always be relevant!). What are downsides, relative to flanged connections?
The applications I'm dealing with are wastewater, water, maybe sludge at up to piping PN16 and temperatures in the 0°C - 100°C range; and sewage gas in a pressure range up to 100mbar and the same temp. range.
[ul]
[li][/li]
[li][/li]
[/ul]
