  • Congratulations Danlap on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Flange face coating
mariolucas75
88
Dear Forum,
Your advise is needed.... in what cases the flange faces are coated ?
I have a spec where 20 mills coating thickness is specified on sealing face of a flange (RF flange ).... 20 mills makes 0.5mm and this is the order of depth of the flange face rings.
Isn't the sealing capability compromised in this case ?
Lots of thanks
OP
The issue with plating, it does not plate uniformly. There has to be a note the flatness
Requirement applies after plating.
The plating house can not or will not guaranty flatness. So it's upto the machine shop to
Dust off the sealing surface after plating if it does not meet the flatness requirement.
If there is a conversion coating it will be removed and has to be reapplied.
Heat exchanger girth and nozzle flanges are pretty routinely coated with epoxies of various kinds. Given careful application and proper gasket selection it can work just fine.
Mike
