hari sankar
i need to analyze 4 inch 1500# wnrtj flange. when i modelled cad according to pipe data, i am getting a clearance of 6mm between the flange faces. when i referred ASME B16.5 ,a 3mm gap between flange face is mentioned. In real time, will the gap between flange faces be zero after applying the bolt preload?
