I am trying to verify the loading capabilities of a flange with two seperate 4 bolt patterns and a center through hole. This flange will see tension loading across the thickness of the flange. It is made of 2.25" thick A36 plate steel, attached at the threaded bolt pattern by four 1-1/8"-7 A574 cap head screws. The other bolt pattern is countersunk 1.125" and attached with 1"-8 A574 cap head screws. I just want to verify there is adequate safety factor built into this part and have not performed an analysis in this manner in many years. Attached is a sketch of the flange face with dimensions.
