sdz
- Dec 19, 2001
- 563
I have a column which is part of a sway frame, pinned connection assumed at base plate, so it basically acts as a cantilever with load at the end. When calculating ?m to AS4100 5.6 what sort of restraint can I use at the base plate? If the critical flange is unrestrained then ?m=1.25 (Table 5.6.2); if it is laterally restrained then ?m=1.75 (Table 5.6.1).
