StructuralAddict
In AREMA, there is this requirement about splicing the flange of a flexural member "No two elements in the same flange shall be spliced at the same cross section". So, for a bolted built-up girder whose flange consists of 3 cover plates: my question is what is meant by element? Like are all 3 cover plates considered as one element of the flange? Or is each cover plate considered an element of the flange? Like should I splice all cover plates at one section? Or should I splice the cover plates at different sections?
Thanks.
Thanks.
