Flange type
HOUARI YAHIAOUI
Petroleum
Dec 13, 2017
29
Hi experts;
please, what isthe differencies between hub flange and pad flange?
Hub is the the part of the WNRF with the taper.
A pad is of different construction, and often welded into something. Therefore it doesnt have a hub.
Hi Houari Yahiaoui,
You can find more information about pad flanges using the term Studded outlet flange.
The link XL83NL provided is amazing :p
Hub flange could also refer to a slip-on flange.
How about you post a drawing, sketch or picture of the two as "hub" and "pad" are not recognised terms in ASME B16.5 and so can mean different things to different people.
See ASME VIII Div 1 figure UG-40 (a-1) and (a-2)as pad flange.
