Hi, i am designing a truss bridge. Is it possible to use fabricated steel section like I girder with 450mm deep [gross], 550mm width flange, 35mm thick web and 40mm thick flange?
I know the boundary in AASHTO/AISC for limiting the minimum width of flange and thickness of flange and web due local buckling, but i don't seen any maximum limit of flange width versus deep of beam of I girder.
Is possible to use larger width flange I girder/member comparing to it's deep?
Regards.
Regards.
