I have a question about flare design on a tank battery oil/gas facility
Situation: we have waste gas from atmospheric tanks 0-10 oz/si, a pressure vessel of 1-4 psi, and another vessel of 10-20 psi, all going to the same flare that has only 2 inlets. when we tie the low pressure vessel and tanks together, we see gas leak from the tank due to back pressure from the vessel at 1-4 ounces of pressure. both inlets to the flare have separate piping going to the flare
the two solutions I'm thinking about are
1. put a third inlet to the flare and have all three sources have different inlets so that there'll be no interaction of pressure OR
2. size the flare line for all three lines as one, but have enough pipe size to where there might not be any back pressure on any of the vessel
anyone with this experience before? any thoughts?
As much as possible, do it right the first time...
