HI ALL!
We are about to design a flaring gas recycling system for a LPG plant. It will include a low suction pressure compressor attached to the flare header downstream KOD and upstream the flare. Also, a water seal liquid is going to be installed before flare in order to avoid backflow at very low flowrates and to improve suction control for the compressor. Pressure suction control is to be done by means a recycle control valve between suction and discharge of the compressor. Discharge of compressor is expected to be returned to LPG plant.
The system is to be designed for handling up to 60,000 Sm3/day of flaring gas, of course it includes only some continuos vents from different pressurized drain vessels. Emergency flaring for the plant is estimated to be 2,000,000 Sm3/day (design conditions for water seal).
Could anybody share the design/operational experiences with such a system?
Do anybody have some suggestions in water seal design in order to avoid pressure fluctuations during low flaring flowrates?
Please see attached pdf.
Thanks in advance.
jeap
Thanks in advance.
jeap
