I wish to produce some steam by using the energie of smokes resulting from an furnace of combustion which produces 40000 kg / hour of smokes. The flow of smokes which will be used for the production of the vapor is 7000 kg / hour to produce 150 kg / hour of vapor. Given that the quantity of vapor is far too small of a boiler to build using a traditional steam
drum, I thought of making circulate more water than steam needed and at a pressure where it
doesn't evaporate in the coil, then direct the flow to a separation
tank(small drum) to vaporize at pressure required. I wish to have suggestions concerning the design of the valve allowing this depression and the feasibility of this solution. The vapor generated in 5 bar will be used to warm the fuel oil by the intermidiaire of a heat exchanger.
thanks
thanks
