Abhijeet242
Hello community,
I am working on a selection of control valve, which will regulate the inlet to the Flash vessel. The sizes of the inlet and outlet of the valve are DN600 and DN1800.
Is it realistic? Are there any flash vessels with the inlet flanges more than DN1000 or so?
Also one more question, what are the typical control valves ( I mean which type: Globe straight passage valves or Angle valves) used at the inlet to the flash vessel?
This question I ask specifically, because I assume the flashing is common inside these valves? is it right?
Thank you community for the help.
