Vicker85
- Jan 27, 2014
- 31
Hello Experts,
I from a mechanical background but seeking some advice on basic Sizing of a Vertical Flash Tank/Vessel WITHOUT Mesh Pad. The flow of incoming condensate is just 3000 lbs/hr (so low!). The vent and drain both go to a Surface Condenser of a power plant.
I searched on this forum and found out that to size the ID of the vessel, we need to have the max permissible velocity of flashed steam. And this as per GPSA Engineering Data Book is :
Vmax = (K) √[ (dL - dV) / dV ]
where:
Vmax = maximum vapor velocity, ft/sec
dL = liquid density, lb/ft3
dV = vapor density, lb/ft3
K = 0.1 (??), ft/s
BUT as per EPRI CS 2251 (Recommended Guidelines for the Admission of High Energy Fluids to Steam Surface Condensers), the max permissible velocity of flashed steam is :
Vmax = 5 x √Vs
where:
Vs = Specific Volume of Flashed Steam, ft3/lb
For the data that I have, I am getting significantly different results!!
Could someone guide on what would be the more suitable criteria for max velocity as this dictates my tank ID for the given flow.
where:
K = 0.1 (??), ft/s
Vmax = 5 x √Vs
where:
