TechARA
- Apr 25, 2008
- 5
Recently we have experience a flashover on a newly installed 100/133 MVA, 230/13.8 KV transformer cable box. The flashover happened two days after the transformer was energized in one high voltage (230 KV) oil filled cable box. An internal high energy arcing occurred in the transformer cable box between the box cover and top shield holding points.
My question: what is the optimum radius around the conductors (insulation distance between current carrying conductor and box wall) that will ensure cable box safety? Is 350mm is enough?
Also, what is the adequate paper insulation thickness around the conductors? Is 3mm is enough?
Is there any pressure relief device that can relief the generated pressure by high energy arcing flashovers?
