Flat Pattern of Fan Blade
sloth4z
132
I am trying to figure out the flat pattern of the blade for the following fan. I have been successful in creating the solid model, but I cannot figure out how to make the blade into sheet metal. I have tried several methods and the closest I got was making the blade out of a surface (using multiple trim features), and then thickening the blade. I should be able to make the blade from two bends. No matter what I try I cannot get the bottom portion of the blade to bend properly. Can you guys offer any suggestions on how to do this correctly?
Just as a thought... Those fins could be created by using a sheetmetal loft then using whatever series of cuts to your calculated shape of the fin, then you can generate a flat pattern.
{o,o}
|)__)
"que?"
Work: Dell Precision 380-PENTIUM D 840 -PNY QUADRO FX3450 Drivers 77.56-2GB RAM--SW2007 SP1-RHINO 3.0 SP5
Play: Intel X6800 Core 2 Extreme - Asus P5W64 WS Pro i975X -2GB Corsair XMS-EVGA NV7900GTO(Mod. GTX Bios , FW93.71)-74GB Raptor-250GB WD Caviar
If you are using the surface of the main body (the funnel shape) to cut the fins, the resultant cut will create a bevelled edge on the fin, and that will prevent the fin being flattened.
You will need to somehow make a "normal" cut across the fin.
[cheers]
