Flatness & Plating of octagonal ring gasket ASME B16.20
AshaPatel
11
from where to check the flatness & Plating of octagonal ring gasket. If the gasket is as per ASME B16.20. Not find in the B16.20.
Flatness should be a customer or process requirement and the plating can be evaluated with a no or destructive technique analysis.
