engahmedbahgat
- Feb 20, 2014
- 40
good afternoon, I have a question about floating ball valve, when this valve is closed, the pipeline upstream pressure pushes the ball against downstream seat ring to attain tight seal, at this case I imagine that the ball as pushed toward downstream seat, it pushes away from upstream seat, so the valve cavity will be connected to pipe upstream pressure and if I trying to open body bleed to depressurize the cavity, it won't be depressurized, it that true or not? and what will be the case in open positions? thank you in advance
