JStructsteel
I inspected a home this weekend that has floor joists supported by wide flange beams. They are offset and lapped about 1'-0" on each other. They are starting to roll over, and was wondering if the normal detail should have been to put some blocking in at the supports. Also, at the end it doesnt look like there was any blocking where they are supported on the walls. there is some x blocking at the mid-span.
Do you think to remedy this to add some blocking? this will help stop them rolling, and stiffen up at the support.
Jim
Jim
