diapensiya
Chemical
- May 6, 2014
- 23
In our plant, we have a steam valve which controls MP steam flow to a reboiler of a distillation column. I investigate whether it is possible to increase flow through this steam valve by changing the valve (internals).
The type according to documents is Masoneilan Camflex. Exact details are not available. Checking the Masonailan handbook, I expect it to be a rotary valve (possibly butterfly) and to have linear flow characteristics or equal percentage. Quoting from the booklet: "The Camflex II valve has a modified linear flow characteristic, which is the same in either flow direction. It can be easily transformed to an equal percentage when equipping the valve with a positioner 4700 series, 8000 series or SVI Smart Valve Interface".
However based on plant data when I draw steam flow versus valve% opening, I see a flow characteristics of a fast opening valve. See drawing.
Why does it look like this ? Before finding info on the type of the valve, I thought that this was due to the valve being fast opening. Now I do not understand why the graph looks like this.
Is it possible to increase the flow through this valve more than 6000-7000 kg/h by changing the valve or is it limited by the process ? Why do I see more variation after 50% opening?
Thanks!
Thanks!
