Had a client that had a basement wall badly failing. We built some false walls and rebuilt the wall. No issues
As the contractor was waterproofing the wall he figured he would go ahead and make sure the rest of that wall (not failing) had gravel/drain pipe. Well now the garage slab is pouring out gravel and he is super nervous about doing anything (rightfully so). I am heading out there this afternoon to try to come up with a solution. I told him pumping flowable fill may be the best option as you will never get anything compacted back up on there. Here’s a picture. Thoughts?
