Flowline Corrosion protection
josito
Petroleum
Oct 4, 2007
4
0
0
CL
Need some information about best method/product to protect against corrosion 8" Carbon Steel flowline after hydrotest, line is planned be water filled for and one/two years another part of project be completed.
Contact Corroless and ask for their environmentally friendlies.
Depending on where you are, you may also need a biocide and an oxygen scavenger. Talk with the chemical companies and let them know your hydrotest water source and quality specification.
Steve Jones
Materials & Corrosion Engineer
What is going to be in the pipeline later? If you will have a rust in the product quality specification of any kind, clean and dry the line and cap with N2.
If its a flowline, I was thinking there's gonna' be a lot of well materials, sand, bit parts, mud, oil, H2S, CO2, wax, hydrates, probably N2, and hopefully a little gas and/or oil, so any special cleaning (other than removing construction junk) now might not be needed at all.
Guys,
I received the information requested by REP, the product is BACTIREP 1418 it's a biocide and treatment with 2000 ppm, protection is for one year.
