ProcessRookie
Chemical
- Feb 11, 2013
- 41
Hi All,
Does anyone here have experience of recirculating flue gas back into the furnace chamber as a means of heat recovery? The concept is that combustion is only required to raise the exhaust temperature back up to furnace temperature set point, the gas will continuously recirculate with only the excess combustion products being vented from the stack to atmosphere.
I'm putting the feelers out to see if this is a well known application. If anyone has any experience to share that would be very helpful.
Cheers,
PR
The scientist describes what is; the engineer creates what never was.
Cheers,
PR
