carla00
- Jun 16, 2005
- 22
Hi
Could anyone point me in the right direction ?
I am trying to work out an inlet flow rate (or pressure, whichever is easiest)required for a water sprinkler system.
All the info I have is the outlet flow rate and pressure of the nozzles, and pipe specifications and layout.
I can't use Q1 = Q2 (sqr p1/p2) because I dont have P1 or Q1. I tried guessing P1 as a pressure higher than that of the nozzle (assuming that the pressure in the pipework is higher than that of the nozzle) but the resulting flow rate was greater than that of the nozzle. Surely it should be less ?
I'm probably going about this completely wrongly so would appreciate any assistance.
Cheers
Carla
Cheers
Carla
