bill318
- Sep 11, 2004
- 43
We are using 0-2 PSI pressure sensors to measure the fluid level in recreational vehicle holding tanks. The sensor assembly is made by another company using pressure sensor dies from a well known sensor manufacturer. The dies are housed in an ABS plastic fitting and the wet side of the sensor die is protected by a layer of what I believe is Fluorosilicone gel. This gel forms the protective diaphragm of the sensor.
The problem we are having is that the sensors are failing due to water and/or gas migration past the edges of the gel diaphragm. This migration is causing corrosion of the sensor die underneath the gel and its subsequent failure. The failures are only occurring on sensors installed in the gray water and black water tanks. The gray water tanks hold waste from sinks, showers, dishwasher and cloths washer. The black tank holds waste from the toilets only. The fresh water tanks have very few failures.
Upon removing the defective sensors, it appears that the gel is shrinking and curling up on the edges, loosing adhesion to the plastic housing. In some cases we have also noticed an off white concretion that forms a layer over the sensor diaphragm and plastic sensor housing. This layer is very hard and prevents the diaphragm from transmitting the small pressure changes to the sensor die. So there are two failure modes at work.
Can Fluorosilicone gel oxidize or even shrink in the presence of household chemicals and human waste products found in these tanks?
The sensor is very cost effective and we would like to continue to do business with the company that makes them for this purpose. However this problem needs to be solved and I think the answer lies in finding an interface material that can take the place of the silicone gel in this harsh environment. The layer of gel is no more than 1/4” thick and 3/8” in diameter. The only material I could think of to replace the gel would be synthetic oxygen safe grease. The grease should stick to the plastic parts and provide a good seal and not react with oxidizing agents/chemicals in the water. Then too, I was hoping that the grease would not be as prone to letting concretions form on its surface. This replacement interface material must not react with the very thin layer of Fluorosilicone gel that covers the surface of the stock sensor die. It must also be plastic safe and its own surface tension and adhesion properties must hold it in place. It would be nice if the new interface material were non-toxic and food safe so that we could use the same sensor for all three tanks.
Sorry for being so long winded, but I wanted to provide enough information to work with. Any help on what is happening to the current gel or possible gel alternatives would be appreciated.
-Bill-
-Bill-
