guilio2010
- Nov 8, 2012
- 80
If you look at the ignition curve for resistive load, Figure B-1 page 28, I'm surprised by what the FM shows vs. some of the post that are listed on this site for intrinsically safe. Most intrinsically safe that I have worked with keeps the power minimal, in the mW, however, from the graph, 12V @ 5A will not have enough power to spark/ignite the gas? If this was the case, then 60V should be able to go to 1A, however, this is not the case according to the graph. The only thing I can thing of is maybe 12V is not enough to cause a arc between the air gap, ie switch closing and the voltage gradient increase as the switch gets closer to the contact point? Has anyone actually proved or done a test of this nature with explosive gas and arcing 12V with 5A?
Thanks,
guilio
Thanks,
guilio
