Foaming MDEA problem 1
Aaronb82
Petroleum
Jul 27, 2010
How is foaming measured in the Lean Amine sample? What is considered too much foaming?
Too much foaming is defined by not being able to make specification on the treated gas. OR, if amine losses exceed the design.
here is 1 link I googled up, I remeber some lab test where you just took a sample of the amine and shook it, then added a drop of oil and shook it again and noted the difference.
Dear Aaronb82,
You could see in the appendix of this following reference from Pall for the method:
Once I was informed by an MDEA manufacturer that they use these following numbers to interpret the result of such analysis and determine the severity of foaming:
Rating Foam Volume Break Time
Nil < 10 ml < 5 sec
Slight 11-60 ml 6 – 20 sec
Moderate 61-125 ml 21 – 30 sec
Severe > 125 ml > 30 sec
Hope this help
What would cause the Recyle H2 gas leaving the Scrubber to be 150 degrees? The lean amine is 130 degrees and the gas going into the Scrubber is 95 degrees.
The amine reacts with the H2S to produce a water soluble salt. This reaction is exothermic, hence the higher outlet temperature.
