Folding A1 Paper into a lever arch file
Engineeeeeeeeer
43
Does anyone have a method for folding A1 size paper so that there is one A4 side protruding, which is then hole punched and put into aa A4 size lever arch file.
The A1 drawing can then be accessed by simply folding out the drawing, and not have to remove it from the ring binder file. This in my view is easier then having lots of plastic folders.
Looking forward to any suggestions.
One thing that I can sugesst to you is filing strips, they are a self adhesive pre-punched strip that you can attach to one egde of your folded A1 drawing - or any document or magaazine that you may not which to whole punch or use plastic pockets. It may require folding the A1 slightly different, I once knew of two differnt ways, but for the life of me can't think of the second way which I think would work in this situation.
