WKTaylor
Well-known member
- Sep 24, 2001
- 4,148
Folks...
I am developing a data base for the wide range of engineering materials used within my company.
As such, I am looking for YOUR in-put regarding the following:
A. What would a USEFUL material database "format" LOOK LIKE??? IE: How should data be represented and how should flow-down paths to material properties(*) be represented?? I have outined [below] some useful material properties... any others I'm missing???
1. mechanical [strength, stiffness, toughness, etc]
2. physical [chemistry, forms available, etc]
3. environmental deterioration/afffects [corrosion, chemical resistance, etc]
4. fabrication, usage and limitations [machinability, weldability, bondability, formability, testing, etc]
5. useful information such as availability, cost, obsolecence, etc.
6. application specs and specific material stds [Mil-, NAS, ASTM, AMS, comapny stds, etc]
B. What do You consider essential/useful/specific material properties(*) for the following materials families:
1. metals
2. plastics and rigid foams.
3. elastomers [monolithic & reinforced]
4. adhesives & sealants & primers [epoxy, acrylic, silicone, polysulphide, urethane, etc]
5. fiber-reinforcement materials [glass, graphite, kevlar, ceramic, fibers-tape-cloth, etc]
6. inorganic & organic finishes [anodize, alodine, primer, polyurethane, etc]
7. ceramics and glass
8. Sandwich-Panels [honeycomb panels, facings, core, etc]
9. petroleum products [Oil, grease, solvent, coolant, etc]
10. non-petroleum based cleaners [water-based detergents, alcohol, etc]
11. expendable manufacturing materials [gloves, rags, tape, vacuum bag film, putties, knives, tool-bits, etc]
Regards, Wil Taylor
1. metals
Regards, Wil Taylor
