pelelo
Geotechnical
- Aug 10, 2009
- 357
Engineers,
NAVFAC Design Manual DM 7.2 provides approaches of computing Ultimate Bearing Capacities for footings on slopes and on top of slopes.
For footings on top of slopes, if the footing is located "far" (e.g b is high) from the slope, bearing capacity can be computed using the traditional bearing capacity equations. See Attached.
My question is, what is the value of b (b = the offset between the edge of the slope and the footing) to consider a footing as "far" enough to use the traditional BC equations?
This is not clear to me.
