I'm looking around for some answers and i'm struggling to get much online, and my college notes didn't go into this.
I'm researching for a design we might have to look into soon. I have a glass tube which is leak tight but kept at 60 psi with Helium glass running through it. This glass tube will be going through a vacuum chamber (The vacuum chamber is required because the glass tube will be cooled in this area to below -100°c, the vacuum chamber removes moisture from outside the tube).
where can I find resources on determining the force which the tube would be experiencing under this vacuum? The glass tube is strong enough to hold 60psi, but when it enters the vacuum chamber the pressure difference is going to cause more stress on the glass tube. Fusion and Inventor aren't able to run this analysis (I can run a normal stress FEA, but i'm unable to simulate the pressure difference)
Thanks.
Thanks.
