Okay.. re done and I hope for the last time. Am I right this time????
Set 1/4, the right side bearing would see a force of (37.125*15312.54=35.25*15312.54+73.5*X) =390.626 pounds. The left side bearing would see the same force (36.375*15312.54=38.25*15312.54+73.5*X) but as a negative value of -390.626
Set 2/5, RS (39*15312.54=33.5*15312.54+73.5*X) =1145.836 LS (34.5*15312.54=40*15312.54+73.5*X)
Set 3/6 RS, (40.875*15312.54=31.75*15312.54+73.5*X) = 1308.064 LS (32.625*15312.54=41.75*15312.54+73.5*X)
When these forces are combined the net result is a pull of 1308.064 pounds on one bearing with an equal pull in the opposite direction on the other bearing.
This works out roughly to an ISO value of G120.. I am pretty sure I will see this rotor back soon to balance with the teeth installed.
